T3 Top VS. T25 Bottom
GODCHSR
Car: 1996 Nissan 240sx
What were some of the fitment difficulties that you may have come across when using either of these setups?
I can imagine that the T3 TM generates more heat because of the longer downpipe.?.?.?
Was is difficult to get IC piping onto the T25 BM? It looks like a tight fit.
Preferrably I'd like to keep my bends clean and a good inch from rattling on anything.
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
hey man i think your the same guy who wants to buy my block. if so just email me your number and il get back to you.
WDRacing
Everything is dependant on the kit used. But for the most part, everything fits the way it's supposed to. There is usually a need for some heat wrap or a shield on the MBC. But other then that...good to go.
WD
GODCHSR
Yeah that's me... assuming youre the guy I emailed??? hehe
GODCHSR
WDRacing wrote:Everything is dependant on the kit used. But for the most part, everything fits the way it's supposed to. There is usually a need for some heat wrap or a shield on the MBC. But other then that...good to go.
WD
Most of the pictures I looked at onfirmed this. I was nervous about going with a T25 kit though because my plans are to eventually build into the 400s. This is a Daily Driver but my goal is a 10 second DD. (Go ahea and laugh I guess) I know 10 seconds on a T25 would not likely be a DD but fully stripped down.
Are there any bottom mount T3 manifolds that are production? (Not custom)
eazye2000
Car: S13 KA-DET
10 second daily driver is hard man. It's going to require a bit of power and a lot of weight reduction. I consider myself to have one of the 'best' T2 setups and keep daily driveability. Which is arguable... But I have all the creature comforts. Power steering, A/C, wiper washers, full stereo with 2 amps and a single sub, etc etc.And I run low 12's with slicks with crappy track prep. Traps are about 119-120.
To get into the 10's, my suggestion is to get an automatic transmission. I personally think switching gears in a manual in a drag car is inefficient. You will loose a good amount of time switching gears.
I really don't know what your goals are. I'm just trying to show you both sides of the road with the information I know.
Here's a calculator that I use sometimes to try and figure stuff out. The drag racing part of it is down, just scroll a bit. http://www.golenengineservice.....htmlBut the guy who owns the site is local, and used to build motors here on the base as a private contractor. The guy knows his stuff, and I've always hoped he wouldn't put a bogus 'calculator' on his site...
GODCHSR
I don't plan on losing any comfort items except for maybe the Power steering. I may just consider a relocation of the PS depending on the turbo setup.
I think 12s is my likely goal to achieve by Fall with the investment I have available. 10s is something I's be shooting for by next summer.
I assume that 10s on a T2 is just not likely?
I wish I'd say I'd done more research on drag in this car but it seems like most of what I keep finding is drift related.
SO... I should state then that my current goal is not 10s... it's low 12s with as little engine work as possible. In fact I'd like to see what kind of times I could pull on a fully stock long block.
eazye2000
Car: S13 KA-DET
GODCHSR wrote:SO... I should state then that my current goal is not 10s... it's low 12s with as little engine work as possible . In fact I'd like to see what kind of times I could pull on a fully stock long block .
I don't think you are talking about a daily driver anymore. Reliability will be questionable with a stock block and that much power. Unless you go stand-alone and get someone who really knows their stuff about tuning. At least replace the headgasket with a FelPro or something.
That's just my $.02. I'm just trying to point stuff out for you. Not trying to be negative at all.
WDRacing
10.9s can be done with 400whp and some fat soft drag radials. Not that far of a leap at all for a daily. Although you aren't going to do it with anything T2 related...unless you have two of them...heh.
GODCHSR
I appreciate all types of advice, critical or not.
A 12 second daily I am 100% sure I can get on a stock block.
The 10s... ehhh let's say hat's why i am buying and building a second block from the guy up there in post 2 or 3 I think...I figure I want to SERIOUSLY push the stock block once that secondary 8.5:1 block is built. I have no idea what stock blockers can or have done but I'm going to find out! hehehe
Honestly I don't have any real belief that a 10 second car can be had on a stock block, and it's not really my goal but to me the stock block is worth a couple hundred dollars and if I trash it before I pull it out that's entirely fine by me.
GODCHSR
WDRacing wrote:10.9s can be done with 400whp and some fat soft drag radials. Not that far of a leap at all for a daily. Although you aren't going to do it with anything T2 related...unless you have two of them...heh.
I don't think so either considering even the 300zx was hardly able to pull 10s on stock Twins. I think there was only a handful (if that) that got into the tens on stock blocks and turbos combined.
Obviously we've got a slight weight advantage (hahaha) more like 550 lb lighter! (or 800lbs for the 2+2)
So I figure if they can I have a shot... allbeit not a very good one. I think a light strong drivetrain could add a lot of potential.I'm looking at 1 piece aluminum shaft hooked into a Z32 NA LSD... obviously a light flywheel and strong clutch too.
All that aside though:If I simply did go with a T3 setup are there any manufacturers with a bottom mount T3???I have not seen one yet but I don't know all the KAT vendors yet either.
240RB1
92 Nissan 300ZX Z32
Um if your still interested email me to the adress from craiglsit and well go from there.
GODCHSR
I just gotta find a truck from someone.
