t3/t4 turbo, and possible clearance issues?
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
I got my hands on a turbonetics t04b super h .63 ar turbo, and considering using it on my ca. From searching I didn't find any posted issues with closing the hood, or clearance issues with a wastegate hitting the fender wall.
Can anyone give a heads up on things to watch for or to expect when installing a turbo like this. I've read on the sr part of the forums a problem with ebay top mount manifolds colliding the turbo with the master brake cylinder, so recommendations on manifolds will be helpful too.
Thanks!
m_wolfenden
Car: nissan 240sx
im running a t3/t4 hybrid.....dont know about the ebay manifolds i had a custom one made...provb ur best bet
21FOX21
I would say go with a custom manifold that is what I am using with my t3/t4
trevr
Any possibility that any of your fabricators will make another one for me and the cost?
boost_boy
trevr wrote:I got my hands on a turbonetics t04b super h .63 ar turbo, and considering using it on my ca. From searching I didn't find any posted issues with closing the hood, or clearance issues with a wastegate hitting the fender wall.
Thanks!
Those ebay manifolds will definitely cause you some clearance issues. I have one on my car and had to modify the hell out of it, but it functions just fine with no leaks and a properly sitting turbo.
Dee
trevr
Dee, just curious, where did it not clear? I believe your using a similar turbo the t04e - right?
I was just chatting with someone who has an ebay manifold, he informed the turbo cleared, but had limited room for exhaust/intercooler piping.
beans33
Car: 1993 ca18det 240sx
Im using a ebay manifold with a turbonetics t3to4e. I have no clearance issues at all. I can provide pics if you like ?
trevr
I'll never turn down pics! tmastronardi at stny.rr.com
Do you remember which ebay seller you bought it from?
beans33
na i dont sorry. But they do all look the same, they may not mean much though. Ill post pics tommorow morning.
slideordie85
Car: 240sx
I have a ebay top mount manifold running with a T3/T4 .50 and I dont really have any clearence issues.
It does however run REALLY close to the BMC. I havent had any problems with my brakes or boiling the fluid yet though. No leaks on the Mani and I boost just fine.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
well as you can see right here, EBAY manifold (altho re welded, its unmodified) clears with about 1/2" to spare on the brake master... I see no issue with this other than the heat, which is easily remediable with a turbo blanket, but ive had no heat issues.
