king_johnthegreat »
https://forums.nicoclub.com/king-johnthegreat-u2837.html
Wed Mar 05, 2003 4:29 pm
I would say that you could simply use the water lines meant for the heater core to supply water to the turbo, and route it back into the engine. There may even be plumbing fittings available to do the job. I mostly see 3/8" pipe threads to 5/8" hose fittings for the water inlet and discharge from the turbo. Using this as an example, you could get several feet of 5/8" heater core hose from the autoparts retailer near you, and brass fittings from home depot, if the autoparts store doesn't stock them. Use two "T" fittings, and put it inline with the hoses going into and out of the heater core. Connect the two sections of hose to and from the turbo to the hose fittings on the bearing section, and clamp them onto the T fittings in the water lines. For added cooling, put a water/glycol cooler in the line feeding into the turbo, with a small eight inch electric fan. This should make all the difference in the world; and even with the cooler, I bet you could do it all for under $100.John
