nissanfanatic »
https://forums.nicoclub.com/nissanfanatic-u21678.html
Sat Jul 23, 2005 6:03 pm
Compressor wheel trim doesn't affect spool very dramatically. Given it will require higher impeller speed to deliver the mean airflow of a smaller trim wheel, this RPM change should be a split second difference. Nevertheless, boost should build until the wastegate opens after 3k. On my T04B, I hit full boost @ 4k, maybe slightly less and I run a .69ar turbine. You should not spool later than I. Check your exhaust manifold for leaks, check for exhaust restriction, check for a dirty air filter, check for boost leaks, check compression, and lastly, look at your impellers. Get back to us with the results to those inquiries.
