t3/t04e turbo help
240sxr33
Car: Cars (imports)
Hi im going to put a t3/t04e on my sr20det s14 with t28
im just wondering what is going to be lag on the turbo if anyone is running t3/t04e on the sr what is the spool time what rpms
Another question can i run 10 psi on t3/t04e without upg the fuel system and what kind of will it give at 10 psi hp ?
Thank you
S13240
I doubt you can run 10 psi on a t3/t04e setup, but hey you can try it. I think it's gonna run lean as the t3/t04e is huge compared to a small t25 or t28 and flows lots more air. If you're planning to run 10 psi I hope you'll go with a wastegate with a 10 psi spring since I don't think there's any lower rate than that.
240sxr33
Car: Cars (imports)
i got 6.5 psi wastegate i going to increas the boost with mbcwhat kind of hp can i expect at 8psi
S13240
wow I didn't know they would go that low. I just learned something new...anyhow it's hard to say since you need to list down all your mods first and then everybody here can guestimate. If you get a chance though, you should have it dyno tuned asap! Why don't you just stick with the t28 until you get all supporting mods done for the t3/t04e first? Better to be safe than sorry!
f150intally
S13240 wrote:wow I didn't know they would go that low. I just learned something new...anyhow it's hard to say since you need to list down all your mods first and then everybody here can guestimate. If you get a chance though, you should have it dyno tuned asap! Why don't you just stick with the t28 until you get all supporting mods done for the t3/t04e first? Better to be safe than sorry!
when using a tial wastegate you can go as low as 4.5psi. I've got a 6.5lb spring sitting right here in my office.
