??? Which turbo? I mapped them out using Corky Bell's Maximum Boost book as a guild and showed the T04E .50 to be around 300ish at 12-14psi and the T04B V trim to be around 280ish at about 12psi. Am I missing something here?Chezedik wrote:It's the turbo I am going to run, maps out to about 350HP at 10psi. I am excited.
No offense intended, but I'm pretty sure I'll NEVER buy another used turbo again. After three purchases, all of which needed complete rebuilding, I'm burnt out. It'll be new from here on. But, thanks anyhow.Edub1 wrote:I still have for sale a T3/T04E 50 trim rebuilt by Garrett with a factory seal on it. It has a .68 Turbine and a .50 compressor. I was going to install it but I decided to downgrade on account of cost.
KATwo40, how much are you looking to spend?
The turbo can acheive this, but the KA can't with stock redline and cams. For any given pressure, an motor can only flow a fixed amount of air for a given RPM. With more efficient turbos than the V-Trim T04B, people are hitting 350HP around the 15+ psi mark.Chezedik wrote:It's the turbo I am going to run, maps out to about 350HP at 10psi. I am excited.
back to the t04e for me again i guessKATwo40 wrote:It won't spool any faster than a T3/T04E .50. Basically, the T3/T04B is just older technology (like 20yrs old) than the T04E and is less efficient.
Actually, max flow means squat if the motor you are using the turbo with can never reach that airflow at that pressure ratio. In fact to simply look at max flow is misleading. A large part of mapping a motor against a compressor map is to determine what range of the turbo's map the motor will be operating in. Anything outside of this range is irrelevant.KATwo40 wrote:Max flow is higher, yes, but the max efficiency range of the T04E .50 covers a much broader lb/min range over a larger range of PR. Also, the T04B V-trim has a surge line that leans pretty hard to the right.
The T04E .50 is simply a more efficient operator. It's better all the way around. Remember, max flow doesn't mean squat if you're at 50% efficiency. The T04E .50 at max flow is still around 60% efficiency, still higher than the T04B V-trim at the same flow rate.
I tried to agree with you on that one, but the lock-out got me.Edub1 wrote:Never mind the mod shut it down because he disagreed with me. A little bit of an abuse of power but who cares.
