c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Thu Jan 06, 2005 5:50 pm
You don't really need a "kit". Just get a T3 topmount manifold, the T3/T4 you want, a tial (not el cheapo ebay kind) 38mm wastegate (if you choose the SSauto manifold), the feed and drain fittings for the oil, get the proper turbine outlet flange and have a welder make you your own custom dump pipe/O2 housing to connect to the downpipe. You're not going to find any kits out there for the CA.
