Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Tue Sep 05, 2006 4:54 am
Yes, what the deal is this: A T3/T4 is a T3 turbine bolted to a T4 compressor. The goal is to get some of the spool of the T3, while getting the flow of a T4. So a T3 mani is a T3 mani, since it is the turbine side that bolts up. So long as you don't change your mind, and end up running a T2x or a T4, you will be fine. If you change your mind and want to run T3/T4 later or a GT3x you will be fine. Just be sure that your T3 has a genuine-style Garrett T3 turbine in flange. Some T3's like the Volvo and some Chryslers do not use this flange, and so if you go junkyard you will have to get your mani from JGS. Me, I am running the eBay mani, we will see how long I make it until it cracks.....
