Def wrote:Honestly, for a KA-T, I'd have a VERY hard time going with anything other than a T3/T04E. Go with the 0.63 A/R turbine housing and a 0.50 trim compressor for your power goals. It will spool up pretty nice(maybe full boost by 3500-4000) and be capable of 400+rwhp.
It's 50 Trim, not 0.50 Trim. And a .63 A/R doesn't tell this guy anything about which turbine to use. You must specify what trim turbine wheel as well. And also what A/R compressor housing. Sorry if I am being anal about this(this is the 3rd time I corrected this exact issue this week) but I do not like seeing bad information being continually regurgitated. I'm not picking on you either Def. As I said, I picked on 2 other people for the same reason before you.
But to summarize, to give a proper turbo sizing, you must specify the turbo family(T3, T04 B/E, T3/T4), compressor trim and A/R, and turbine trim and A/R. Some turbos have some other quirks as well, but they are minor and have little to do with the way the turbo works. Those would have more to do with the way it bolts up or connects to piping.
