because it's $170 just for the adapter/ i thought about going v band and if i do i'd do thishttp://cgi.ebay.com/ebaymotors...17877
yeah im not a huge fan of any adapter even if its not ebay, the more pieces the more chances in general to leak or cause problems. i will admit i'm pretty stubborn about keeping the internal wg, but i think i have good reasoning. for starters, i won't be pushing that turbo hard even at my ideal hp goals so i don't think i have to worry about boost creep and the wg not being enough, secondly, while i don't have to go through emissions in the regular sense i do have to have a visual inspection and an open dump pipe would be pretty obvious, and lastly is the price, i don't want to cheap out and get an external wg that will fail anyways and the legit ones are approx $300. the flange itself to make it work wouldn't be terrible, but i just don't want to shell out for something that isn't necessary for this setup.Bumnah wrote:I see that $50 ebay piece making issues. You get what you pay for.
Why do you want to run an internal gate so badly? I doubt you have emissions in your area. Run a standard flange and make a simple down pipe for the turbo. Run an external waste gate, and run an open dump pipe. External waste gates have better response than the internal counter parts. Plus, an open down pipe sounds pretty bad a**.
jeff i think this is your best bet. dont be a cheap skate.
just wait and seemrgreeneyes wrote:lol "budget" turbo build.
i'm not being a cheapskate, shich is why i'm not going with the ebay pieces, but for $170 just for the adpater its retarded. for that price i'm gonna pick up a used tial 38mm and block off the wg hole.brizanden wrote:jeff i think this is your best bet. dont be a cheap skate.
lol, at this rate, my SR will be running before yours....White Comet wrote:just wait and see
lol.... its an h23 in a 4th gen lude. i even said lude in my previous post. anyways, that turbo stock is internal. i just welded up the holes on the exhaust housing shut.Logan76 wrote:Nice turbo LS, but I think he wants a way to stay internal, where as you went external with that.
not so much hate, as confusion. multiple threads about twinscrolls, log mani's, and outlets...White Comet wrote:why the hate
