T3/4e on a rb25det
Turboed240sx
Car: 1990 Nissan 240sx(RB25DET)
anyone has a t3/4e turbo on a rb25det?? if yes what numbers and ect???i have a 90 240sx ,im doing a rb25det swap and was thinking of throwing on a t3/4e with 300zx injectors,and of couse i/c and all the basic bolt ons
eh?
Get a better turbo, precision sc61's are t3/t4's but have GT wheels. They don't cost much more than a t3/t4 too.Also an RB25 and vg30dett have the same size injectors.
Turboed240sx
i ave
eh? wrote:Get a better turbo, precision sc61's are t3/t4's but have GT wheels. They don't cost much more than a t3/t4 too.Also an RB25 and vg30dett have the same size injectors.
new t3/4 laying around here thats y i was considering it
eh?
I see, I have 50 Trim .63 A/R Turbine t3/t4 with internal wastegate. It's a standard garrett item. I had to have a new down pipe fabbed for it. I recently bought a turbonectics t3/t4 ball bearing turbo (suppsoed 62-1 comp)If i had to do it it over i'd get the SC61. They go for a little over $700.
You may need to use a spacer between the turbine flange and manifold.
Modified by eh? at 4:26 AM 6/27/2005
240sxed
I thought precisoin sc61's weren't all GT series? I thought it was like you can get a precision turbo the come standard polished, 360 degree thrust bearing, optional ball bearing 1 side, and optional wet center section?
the gt series turbos by garret is dual ball bearing wet center, internal/external of your choice?
eh?
They have GT wheels, not center sections but have options for ball bearing too. Not all GT series are ball bearing though, those that end with an R will be, ie GT30R.
fly240
Car: nissan 240sx
How's the perfomance on your turbo?..
eh?
sucks.. slow spooling, that's why i bought the turbonetics and made sure it had a ball bearing chra.
Imissmyturbo
Car: Car's, Turbo's, sking
I have an "SC61" It's an APG's version of it. Spool isn't that bad. At first I though it sucked but after some tuning and getting used to it I would accually like to go with either an .82 ar exhaust or a T4 hotside. I start to see boost around 3200 in 3rd 4th and 5th gears. I get full boost around 4K but the car really takes off around 4500 to 5000 RPMS.
eh?
OT:did you ever have a problem with your PFC not saving changes?
fly240
Car: nissan 240sx
how is your turbo fitment to the engine......
Imissmyturbo
N
eh? wrote:OT:did you ever have a problem with your PFC not saving changes?
No I never had that problem. I did have a problem with the PFC not working at all since the power battery + wire wasn't hooked up.
y3llows14
I have the GT3251E....its precision series using gt wheel. Very quick spool up.
IMissMyTurbo : A little off topic as well,Im working here in Reading Pa for the summer! It sure sucks down.
