NO NO NO! it goes like this:S13-t25 journal bearingS14-t25 ball bearingS15-t28 ball bearing.... really. So I'd say say stay away from buying an "S14 bb t28" because he doesn't know WTF he's talking about! Think about it: If the s14 came with a t28bb why would all sorts of people in Japan with BOTH s13 and s14 be upgrading to the s15bb if it was the same one on the s14... Both the s14 and s15 have VTC, and if they have the same displacement and they came with the same turbo what would be the difference? Sure, a lil something here and there, but that's not enought for Nissan to justify a new motor designation. SO, the s14 is not a t28! Rebuilding your t25 will range from as low as $300 to $900 depending on what specs you want to rebuild to. The most common options are:mxd wrote:need some info on this,a guy is selling me is t28 bb from a s14and i want to know if its the same a s s15 t28same amount of hp
also how much $ is to rebuild my t25 and how much hp will i get!thanks everybody!
hokiruu wrote:NO NO NO! it goes like this:S13-t25 journal bearingS14-t25 ball bearingS15-t28 ball bearing.... really. So I'd say say stay away from buying an "S14 bb t28" because he doesn't know WTF he's talking about! Think about it: If the s14 came with a t28bb why would all sorts of people in Japan with BOTH s13 and s14 be upgrading to the s15bb if it was the same one on the s14... Both the s14 and s15 have VTC, and if they have the same displacement and they came with the same turbo what would be the difference? Sure, a lil something here and there, but that's not enought for Nissan to justify a new motor designation. SO, the s14 is not a t28!
themadscientist wrote:Ah the internet, what a fountain of mis-information.
The S14 turbo is ball bearing and it is a T28 frame just like the S15, the S15 has internal differences that I am not certain about that makes it SLIGHTLY superior, likely bigger or better designed wheels or improved materials.
People are upgrading to the S15 because it is a little bit better and if it costs about the same why would someone get the inferior model?
:rolleyes
hokiruu wrote:Not the S15 MOTOR, the S15 TURBOCHARGER! That's what people are doing with s14s.
Movingviolation240 wrote:the S15 turbo is the exact same thing, only 2 differences are an inconel turbine wheel and a divider on the wastegate outlet. Same turbine housings, same compressor housing, and all Jap spec S14's were ballbearing, the euro ones were still journal bearings.
I have heard rumors of guys making 300rwhp on a T28, but I'd guestimate that 280rwhp would be more like it with proper tunning and fuel.
You have to keep in mind that the stock S13 or S14 370cc injectors are WAY past flat out at that point, and the stock MAF is also way over taxed. I.E. try it without the proper upgrades and you get to rebuild your motor.
S15 6speed's used 480cc injectors the automatics were still 370.
PaulOrlando, FL
hokiruu wrote:Ok. Thanks for that info Movingviolation. I am currently still deciding whether to buy an s13 or s14 motor for my s14 chassis. So it seems that alot of people are saying that I could buy an s13 and add t28 bb turbo, 550 cc injectors, Z32 MAFS and be well beyond the stock s14 output, huh? If so, by how much, because it will cost thousands more (of course both would have the same basic mods.) If I do that will it also be important to get a metal head gasket, RAS, and valve springs? If so, it may to a real expensive way to "spend the money I save on an s13" because I was quoted a s13 clip for $2k and s14 for $2.5k. Yes, I have a friendly and generous connection for clips, so either one will be in good condition.
