t28 power
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
hi,i was thinking about buying a s14 t28 to put on my s13 redtop.is the t28 alot better then the t25,will i see a big horsepower gain?or anything else like that?is it worth it.and does it bolt right on.any thing you have seen when doing this let me know.thanks,
Hijacker
Car: '92 240sx Convertible
'94 F-150
Good for you
SpeedRacer1
Car: 1990 240SX, G35
Its ball bearing. You will feel a little something. But at stock boost it wont feel all that much better. Remember it only adds 15hp max to the S14 engine. It bolts in place but the water and oil lines will have problems. As well as the compressor sides inlet and outlet pipes.
Phax
Car: Control dynamics
According to Phase2, the T28 is good for about 300rwhp with the appropriate complimentry mods (exhaust, cams, etc). That's nothing to sneeze at power wise. You can go fast enough to scare your passengers and the people who happen to be driving along next to you.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
That's my plan. Usually you need 550cc injectors, valvesprings and metal headgasket are a good idea, and a bigger MAF. Since you need fuel management anyway, I will probably get a Power FC or FCon V Pro and use that to tune it and eliminate the MAF altogether, while eliminating the rev and speed limiters.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Quote »Its ball bearing[/quote]
I thought it was the s15 turbo that was ball bearing, and that the s14 t28 isnt a ball bearing turbo??
hokiruu
That was my first impression, and I embarassed myself by making statements on that. I now own one, and it is in fact bb.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Are the turbines and housings the same size with the s14 and s15 turbos?
hokiruu
The housing and A/R is exactly the same. The onely difference in the s15 t28 is the slightly higher flowing comp wheel, 60 trim versus 63, and of course the inconel turbine wheel and wastegate divider.
