t28 onto a redtop
forsaken
Car: cars, music, pool
What is all required to swap a ball bearing t28 onto a redtop? Im about to buy one, but I dont want to end up over my head with the install. Is it something that I could do myself or should I get it professionally installed?
CaptainHenreh
You take your T25 off, and put the T28 on.
In fact, aren't they even the same housings?
SpeedRacer1
Car: 1990 240SX, G35
BuudWeizErr
It bolts up, but you need to either bend the lines or get some stainless lines. Taka sells the stainless lines you would need.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
the compressor housing is at a slightly difforent angle as well but shouldnt be any problem, another option is the FP Big28 which is bolt on completely but is not ball bearing.
UsedToOwn240SX
Car: Radio Control Racing, Counterstrike
That's exactly what I did, get the t-25 converted to big-28. I can't compare the big-28 with stock since my t-25 was damaged when I got the engine. However, the car pulls very very strong. I'm still running stock boost though. Don't know what kind of increased HP/torque that big-28 makes compared to t-25 at stock boost but it feels really strong.
