flip the engine around the right way!float_6969 wrote:Flip the turbo around the right way?
Ive been debating on getting one but unless the actuator arm is a bit longer or the bracket will benefit me I cant see myself buying one.float_6969 wrote:Flip the turbo around the right way?
You're probably going to have to drill and tap the compressor housing to make something work. You might consider the HKS actuator since the bracket isn't attached and gives you more flexibility.
