t28 compressor wheel swap
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
Can anyone tell me how to swap the compressor wheel on an s14 t28?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
1. Place in box.2. Mail to pro because you are going to have to have it balance it anyway.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
weirdI have to do this tomorrow. I'm going to try it.pictures to follow
hungryjoseph
gmac708 wrote:weirdI have to do this tomorrow. I'm going to try it.pictures to follow
information would be much appreciated!
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
****WARNING****
****GRAPHIC CONTENT****
Please be warned that the following post contains graphic photo's of "turbo Abuse".
I know...I know... It's not pretty but somebody has to try.
OK, Here's the story.
Some of you may recognize the sig about the kids 240SX. Well...we had a little trouble with the T28 and ended up changing it due to the turbo being trashed from something going through the exhaust. Totally trashed the "hot side" of the turbo. Impeller was still good. kept the turbo "just in case" we needed parts one day.
Well. we had a little bo-bo the other day and the bolt holding the filter to the MAF let go and trashed the turbo.
****WARNING****
It is amazing that the housing looked like it had no damage
So... swap the bad with the good
5/16 nut on end of shaft. Left hand thread. Remove old impeller by rotating through bolt and holding/pulling impeller with rag.
Old one comes right off.
replacement
Slide it on
Torque to ???? standard torque about???? at this point we are winging it so much, just lock-tite and and good 50 inch/lbs.
Assembled with old housing that matched the impeller.
Bottom line is... Ya I know... but it worked great. We drove around and everything was back to normal. He had a big date and we got him going.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Just understand that your turbo will be out of balance after doing this. I'm personally not a fan of out of balance things that spin over 100,000 rpm.
hungryjoseph
hey, thanks alot for the pictures man! so you basically just held the wheel down with a towel and loosened the nut
Sil80315
Car: 1991 Nissan 240sx
yeah you deff should of got that balanced esp after putting another t28 wheel on. If i were you. send it to gpopshop.com and have them balance the shaft with a new rebuild kit. the rebuild kit is like 100 and the balance is 65. so for under 200 you will have a near perfect condition t28.
Everyone likes to sleep easy at night
Kalypso
wow, amazing photos
