Eh?nismofly wrote:people are getting 350whp out of this on the sr...would it be the same on the ka? or are you saying because it would need less boost on the ka than it would on the sr so it would peak sooner?
Or you can buy a GT35/40R for less and have the same benefit as the GT3037 without the HKS name.WDRacing wrote:You can't compare the SR with the KA, but you can use a flow chart to see if it will produce enough volume without becoming a heat pump to make good power.
I've seen the GT2835R make 410 on a RB25 GTS-t. So the 2871 should do very well.
Also look into the 3037 and 3030. If I were going with an expensive GT turbo, I'd buy the GT3037 and I'm pretty much a genious so...lol.
WDRacing wrote:For the record, Garrett makes HKS some REALLY good turbo's.
Weaksauce.WDRacing wrote:I think the GT35 or 40 would lag alot more then he's looking for Alan. The GT35 isn't anything more the a T3T4 anyway.
Definitly...lol.nismofly wrote:i think its from right to left, not left to right
Nismo_Freak wrote: I LOVE YOU BRIAN
WDRacing wrote:I LOVE YOU ALAN
Well... yes the KA will make more power on the same turbo at the same pressure.nismofly wrote:haha
i guess what i was saying is i thought the ka, being a larger engine with the same turbo, i would think would make more power at the same boost level...
but as you said it would be good for a 350 whp ka, not comparing it to the sr
GT3071 provides about 16 PSI by 3900 or so on the SR. On the KA I'd cut a good 300 - 400 RPM off of that, the KA is an energy monster if you got stock cams.nismofly wrote:ok Alan, looking at the GT3071R, how much more time would you think it would be to boost, because i do like that one as well...
ive heard that the bigger the turbo the less reliable it can be...let's say im going for 350whp, as reliable as possible, and best possible spool...would the GT28 or the GT30 be more reliable all other thing equal at that pressure...im not sure how much it would be, i know 340-350 on the sr is right around 20psi on the GT28...
GT3071R and GT2871R use the same compressor wheel. The turbine is different(T3 vs. T25), so you have a better speed match between the turbine wheel and compressor wheel for the GT3071R. So it takes less exhaust power to power the compressor wheel if that's what you meant.Nismo_Freak wrote:The GT3071 would actually be more reliable than pushing a GT2871R simply because of the greater efficiency you can run the compressor at to make the same power.
2871R comes in two trims one is the 3071R compressor's 56 trim and the other is the 48 trim.Def wrote:GT3071R and GT2871R use the same compressor wheel. The turbine is different(T3 vs. T25), so you have a better speed match between the turbine wheel and compressor wheel for the GT3071R. So it takes less exhaust power to power the compressor wheel if that's what you meant.
