mdb4879 »
https://forums.nicoclub.com/mdb4879-u186863.html
Thu Sep 22, 2011 10:40 pm
sorry for the lack of searching and my own prep work for this post, but this opportunity kinda just popped up. I just found what i think is a t25g (craiglist post that said sr20det t25, so i'm assuming its a t25g. i'm going to call him in the morning to ask some questions about it, though) with minimal shaft play for $120, and idk if I should go for it or not. also it says for this weekend only cuz he's moving (i'll be sure to make sure it's not a scam), so i didn't really have a lot of time to search and making this thread is kinda a long shot anyways because of the time restraint
here's my situation:
I got my CA in my pulsar about 3 weeks ago and have been tinkering with it here and there. the turbo was, to the best of my knowledge, professionally rebuilt less than 5000 miles ago, but when first got the car driving and was troubleshooting boost leaks and stuff one of the intake pipes became disconnected about a mile from my house. by the time i got back to check it out there was oil all over the pipe where it disconnected. so my thinking is that the compressor side is leaking oil (although i had thought it was a lot more common for the exhaust side to leak). the car doesn't smoke unless i wind it up a bit for a little while (floor it for maybe 10 or 15 seconds, shifting at 6k-6500rpm). but when it does smoke it will only smoke when i let off the gas and will clear up if i rev it freely a few times (possibly valve guide seals, not the turbo?)
i haven't checked the intake plumbing recently to see if and how much oil is in there. also, when i had the motor out the turbo seemed to have quite a bit of shaft play. i know journal bearing turbos are suppose to have some, but to me it seemed like too much. i was thinking of having the turbo rebuilt, but if i can upgrade for only around $120 instead then that would be great. so i guess what i need to know is if my turbo is crapping out or not?
also, i would like to know specifically when the t25g would start to spool and when it hits full boost. for instance, my stock CA T25 will start to build boost at 2300 or 2400 rpm and have full boost by 2800 or 2900. it has the turbo elbow and about a 3 inch long pipe after that and that's my whole exhaust for now.
another thing i've been wondering about, when it hits boost it will go to 10ish psi then drop to around 7. well i looked up explanations of what boost creeping and spiking are and i don't think its either. spiking would be going past the set point (7 psi in this case, right. it's the stock actuator with no boost controller, although i guess 10psi should be normal with a free flowing exhaust, right?) then going back down. well my car will hold 10psi until around 5k-5500rpm. i can brake boost and it won't drop back down, just a steady 10psi then it'll settle around 7 once it's past around 5k. and boost creep would be rising boost as i stay in the throttle, which it's not doing that either. so what exactly is going on? is it something to do with the wastegate or do these turbos really start choking out after 5k because they're so small?
and does the CA turbo elbow fit this turbo? i think i read one of the holes on the elbow has to be slotted, but I would just like some confirmation
it will also miss a little bit once i get past 6k, so i was wondering if that could be the oil or if its an air/fuel mixture or timing problem? and there is a line that is split that goes to the intake boot, and because its split the motor will suck in unmetered air and run lean at idle and cruising and cause it to try to die at idle and miss at cruising. i was messing with it the other day and i think i got it to seal better because the idle smoothed out a lot, but not totally, and it stopped missing when i'm cruising (it always ran fine when i was in boost). i clamped off the line and the motor died, so i'm guessing it has something to do with crankcase ventilation, but i haven't tried taking off the line and not clamping it, but plugging the hole on the intake boot. so even though i haven't tried it myself yet, could someone tell me if it will run fine if i had a hard pipe made for it and just let that line vent to the atmosphere? i would like to figure out why this car does some of the things it does before i go to upgrading it (like spending money on the t25g i am talking about). and it didn't have the high rpm miss before i fiddled with that line (at least i don't think it did. i don't drive the car every day because i'm still working out problems and don't want to get stranded somewhere and my gas gauge doesn't work and i'm trying to only put 93 octane no-ethanol gas in it, but the nearest station with no-ethanol is 10 miles away so i fill up very regularly)
sorry for my total noobness. i do all the searching i can. this is my first turbo'd car, and i'm a workaholic so i don't have too much time to mess with it (i guess i shouldn't have a toy like this if i don't have time for it, huh?)
and once again, sorry for bugging you guys about all this stuff that probably could've been searched. i do my best to search what i can (not using that as an excuse cuz i'm sure i could do better)
