oh man, i guess all 24 of your posts have made sense and never asked a newb question....Canadiancochl wrote:SEARCH!...
Dr.
usually, s15 t28 maxes out at around 300whp. the pulsar gti-r turbo, which is not ball bearing, has a larger compressor housing and can hit about 320-ish whp.Canadiancochl wrote:I'm doing s15 bb t28, good for ~330rwhp . . and thats perfect for me, and a quick spool.
GTiR turbo has a smaller compressor housing. T3 vs. s14 and s15 turbo's t04b. I've never seen them side by side though, so maybe I read wrong. gtir has bigger turbine, .86 a/r vs the .6 of the other two, and the compressor wheel is of different trim. Still, it makes more power than the others.cheez80 wrote:usually, s15 t28 maxes out at around 300whp. the pulsar gti-r turbo, which is not ball bearing, has a larger compressor housing and can hit about 320-ish whp.
an s15 t28 is probably not going to have enough juice to take you very far past the 300whp mark.
If you would like around 300, then go with the s15. Its proven, and cheaper than your other alternatives. If you want response, thats your turbo. If you are willing to sacrifice a little response and low end power, then maybe a bigger turbo. The gt2871r is not exactly a laggy turd, but its not a very fast spooling turbo either. Stick with the s15 turbo for that all around performance that you said you wanted. Youll be happy.tazjig wrote:i have been searching, i figure i would like to make about 300hp and i dont think a t28 non BB is going to make that much, a BB turbo will but then i will be spending as much as an aftermarket turbo, no?
444's are top feed injectors used in the GTRProjex240 wrote:ive seen people run more.15 psi on a stock s13 t25 is normally what people run, 16 psi actually is more the norm with an output of around 250-260.That s15 turbo should have you around 300 at around 17-18 psi im guessing, but of course, you have to have proper supporting mods . Downpipe, exhuast, maybe cams, etc.Youll need injectors and a maf. The stock maf doesnt handle anything over 260-ish. The injecotrs are about at the end of their rope too. The s15 injectors can be found for sale. Ive seen them go for pretty cheap sometimes. The euro ones are 444 and the jap spec ones are 480--check ebay out.
-Josh
Yes. The turbo outlet elbow needs a little grinding because one of the studs is in a slightly different location. If you have an aftermarket one it should already be set up for this.89 240hatch wrote:not to threadjack,but are there any mods that have to be done to the hot pipe or intake pipe when swapping in the s15bb?
alrighty. Thanks for clearing that up. Now I feel dumb b/c I cant count how many times ive told people that. I forget where I read it.Nismo_Freak wrote:
480's are the side feed injectors used in all S15s
S15 injectors are pretty worthless at 300whp ... duty cycles are very high from experience. You should opt for 740's or 550's.
And ANY upgrade to the turbo will require both.RMiller wrote:If you change the injector size or maf, you need a fuel controller of some kind.
