t25/s15 t28 02 housing gasket
bentvalves
Car: 89 Silvia K's
So the gasket kit I got from PNP for my ca18det worked out well for me, except that the o2 metal gasket I recieved, doesnt want to make it over the studs on the hotside of the turbocharger.
Are there 2 different part numbers for this application?
I have some ebay cheapy composite garbage gasket in there now, Im sure it wont last more than a month.
When it starts leaking, Id like to have the right gasket on hand to alleviate problems.
Greg
ca18det240hatch
pretty sure theyre the same. i was running a t28BB on my ca18, but i was still using the stock ca18 o2 housing on it, also the gasket i got was for ca18det, and it fit no problem.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
I used the SR gasket, HOWEVER I had to open up 1 hole a little bigger, aparently the CA and SR turbos are like off by 1mm on 1 stud.
bentvalves
Car: 89 Silvia K's
Yea thats what I was trying to do, open one hole up a bit, but it wasnt working in my favor.
wonder how long the cheapy composite will go for?
thanks
Greg
jt15833
Car: 95' 240SX
what are good gaskets to use? I've got a metal ebay one on mine too and I think there may be leakage
bentvalves
Car: 89 Silvia K's
a good gasket is the nissan one.....its not even a gasket so to speak, more like a compressable piece of metal.
