ashibah83 wrote:$900 to rebuild a turbo....wow.......did you happen to get a written estimate from them because if it was going to cost you $900 the there may be more to that turbo than bearings and seals, the turbine and compressor wheels may be damaged, the shaft may be badly scored, they may need to replace the backing plate or the housings
$900 is into the realm of a good aftermarket turbo new.....
i am aware of that, i just cant believe that, but that isnt crazy, where i am they try to charge 450 to do a PEICE TOGETHER MUFFLER SPECIAL EXHAUST
total bogas
jbracy7 wrote:make sure u be ready to buy another kit (just in case) first time and all
and yea i have alot of time to save up for the rebuid kit and im gonna take my time with the rebuild and everything to make sure it is done right and everything is opperating correctly and efficiently
the turbo isnt going anywhere thanks for the input everybody im definately gonna rebuild it and ive seen a few pretty good write ups on it so ill probably just stick to that
