visser003 »
https://forums.nicoclub.com/visser003-u103551.html
Tue Aug 11, 2009 1:29 pm
The t3/t04 turbo uses a different flange then the t25, therefor you need a new exhaust/turbo manifold. To truly take advantage of the bigger turbo (boost above ~7psi) you will need bigger injectors, a better fuel pump, clutch that can hold the extra power, tuning, wastegate, FMIC.
Research is your friend.
