T25 has shaft play...what to do.
Rosco
Car: 91' SR'ed Hatch
Well, t25 shaft has less than a mm of play . Is it still okay for use? I was hoping to find a t28 bb for under $300, but I don't think that's gonna happen. Engine is out of car still....so I need to figure out what to do before next weekend (swap was going to start friday, but now I'm not so sure so I'm aiming for next weekend)....It's a good thing I decided to re-check everything.
s13sr20chris
rebuilding that sucker will cost you ~$200 so i would say if you can find any good condition t28 for $300(even without bb) it would be good. then you can run a lower boost for the same power and have a cooler intake charge with a larger margine of safety(for knock).
