T25 exhaust manifold
wc
Is there an off-the-shelf T25 exhaust manifold that would position the turbo in the same location as the SR? so the SR turbo outlet and downpipe can be used? Thanks.
- wei
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
SSAC IIRC.
ZiG
Car: 1993 240sx coupe
Most all bottom mount manifolds will work just fine.
bruinbear714
wc wrote:Is there an off-the-shelf T25 exhaust manifold that would position the turbo in the same location as the SR? so the SR turbo outlet and downpipe can be used? Thanks.
- wei
Rumor has it that the SSAC/Megan Racing / ebay manifolds will position the turbo in same place as the SR so you can use the elbow & downpipe... but as with all info, please verify for yourself. I wouldn't be surprised if it is off.
WDRacing
The SSAC and SR downpipe will work.
Kenny_D
Buy a used sr20 manifold. Cut and move the two runners that face the wrong way and weld them to the KA bolt pattern. I just saw a picture of it today and now I might try it.
