Jonny 290 »
https://forums.nicoclub.com/jonny-290-u11793.html
Fri Dec 19, 2003 6:51 pm
Take the JGS unfinished log manifold, and rotate the flange 90 degrees along the axis of the pipe so that it's now a side-mount manifold.
Now move it between the #1 and #2 runners, and visualize it tilted approximately 20-25 degrees up (bring the compressor inlet up). Now you could possibly weld another flange between #3 and #4 runners, at the same angle. The downpipe would be easier, but still not simple. Wastegate is simple, mount it dead center on the log, on the bottom side.
The other setup that I thought of involves the same manifold, only having one turbo top mount, and one bottom mount. You could keep the manifold symmetrical that way, but dear lord would that take up some space. Possibly one side mount and one top mount?
Corky Bell says that turbine oil drainage is good up to about 30 degrees off vertical on any axis. i think you could do it.
boom. twin turbos, spooling quick and hopefully moving plenty of air. i'd pick turbos that would fit well on a 1.8-ish motor, and would be able to flow at least 25 lbs/min each at good efficiency and psi.
