T25 boost limit?
tebsie
Car: 1994 180sx
What max boost level can you safely run on a T25?If you disconnect the vacuum pipe going from the wastegate to boost pipe the wastegate doesn't open and you get huge boost, i know this shoultn'd be done because it will blow the turbo but i tried it once and got a lot of power.does anyone know can this be done safely in any way?
da40
Car: 1995 SE 240sx
well for starters u can get a boost controller the t25 can go up as hight as 14 psi but it wont last long and it will lose efficiancy .you will be ok at 10- 12psi though...do u have a bigger fuel pump or a fmic youll will need these if u dont already have them to run this boost safely and efficiantly
