fast_s13 wrote:bottem mount 3076r wont clear have to go top mount
The 3071r fits - the 3076r fits also -
the ewg housing isnt really going to change mcuh unless ur trying to run LESS BOOST.
the 2871R t3 is NOT efficient to 28psi - it just isnt.
t2 3071R are not junk but they arent terribly impressive either. For a bolt on affair they do the trick just fine.
If you have the money for a proper manifold (peakboost, full-race, or can make your own nice - custom) then go top mount. otherwise its a waste of time anyway. Logs aren't worth putting a turbo beyond a 50 or 57 trim T3/T04e on.
The 2871r doesnt exactly push the limits of the t2 flange... whoever told you that was blowing smoke up your butt. The t3 ones make 5-8whp more usually - and that isnt exactly because of the turbine - its because of the manifold more than anything
