T04E turbine how many psi
KaTdaToplesS13
Car: 94 nissan 240sx convt
i have a T04E turbine and im gonna put on my 94 convt. Planning for Ka-T project. Gonna boost about 15 psi on stock internals and upgrade head gasket jus wanted to know wat is the max psi of the turbine
Also if any one knows around wat rpm its starts creating boost?
WDRacing
The TO4 full frame turbo's are good for more boost then a stock block can handle, so no worries there. I can't tell you when it will spool unless you can give me the specs from the turbo. What size is the exhaust housing? What trim is the turbo.
I had a TO4E with a 60-1 compressor and a .81 AR exhaust housing on my RB20 and it didn't spool until 5000ish.
KaTdaToplesS13
that was quik thanks
exhaust side is A/R .58compresser side A/R .60
WDRacing
Thats not bad then, you'll have boost before 4000 or so. Thats a good turbo choice.
KaTdaToplesS13
cool i picked it up for $400 w/manifold, turbo extension pipe u know the pipe that mount on the exhaust side , and down pipe but i need to buy an external wastegate
WDRacing
Thats a good deal, who makes the mani?
KaTdaToplesS13
not sure but its a cast iron topmount i think its from nsport
TrunkMonkey
Car: 2000 Lincoln Navigator
iirc, nsport uses a revhard manifold.
-demetrius
Structure240sx
that is correct, same manifold i use. thats going to be a tight fit with the tangentail turbo. als o make sur to search about preping the manifold to prevent cracks
KaTdaToplesS13
yeah the manifolds already cracked so i got to get it welded. but u said something about preping it so it wont crack wat do u mean?
WDRacing
You cut in between the runners so the flange can expand and retract.
DRIFTEADOR
make sure you drill small holes at the crack's ends so it doesnt spread
