T04e turbine go w/it or not
KaTdaToplesS13
Car: 94 nissan 240sx convt
hey guys jus got a quetsion. Planin on kade-t. I have an AirResearch T04e turbine. Ive heard the turbo is a bit big for the twincam. Im not planin on boostin over 8 lbs until i change to a thicker head gasket. What do u guys think.
Parts I'll be using for my custom turbo kit:
AirResearch T04E turboRevHard castiron turbo manifoldCustom turbo back and downpipeTial 38mm wastegateCustom Fmic370cc injectors (S13)Apex safcHKS sequential bovCustom catback(muffler and pipe welded)walbro 255lph fuel pump
uncle_louie83
Car: 1993 Nissan 240sx Coupe
mmm...im not exactly sure what to say....its laggy but it also depends what your a/r's are and what trim it is....i have a t04b im putting on which is smaller than the E series if i do believe...mine will provide max boost at 3800 rpms...that might be around 4500 to 5000...dont quote me on that though...
lewis
KaTdaToplesS13
Louie what is the A/R for your turbo. Im not exactly sure if my turbo is a B or an E. On the compressor housing it only says T04 and Ive only heard of T04e so i just guessed and posted that my turbo was a T04e.Opps. If u can get back to me on that it would be helpfull
Florida240sx
I'll take it from ya.It'll be find.Although I prefer for boost to hit later on.Might have to run less than 8lbs depending on your setup.Got anything else besides just the 370's for your fuel?
uncle_louie83
exhaust is .69....compressor is .60...
Jookmasta
that shouldnt be a laggy turbo at all. laggy would be boost coming on at 5000 rpms or later IMO
KaTdaToplesS13
A/r for compressor is .60 and for exhaust is .58. Also a friend of mine has ka-et and hes running stock injectors and hes doin jus fine so i think the 370's will be fine
Modified by KaTdaToplesS13 at 7:58 PM 6/18/2005
RaceBoy69
Car: 240sx 1991 LE
Hi Guys,
My opinion is that if you are using hi compression pistons the t04 will be perfect. Sacrifice a little at the take off but get it all at top end...That's how i like it..
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
RaceBoy69 wrote: using hi compression pistons
I recently found out, that high compression pistons + turbo = BOOM
so thats not a good idea
RaceBoy69
Car: 240sx 1991 LE
I'm using 9:1 comp...and I have no prblems at all ..
Florida240sx
Tuning is what makes you go boom.Lack off or incorrect.
grip_racer
Car: 1997 Audi A4 1.8TM
Florida240sx wrote:Tuning is what makes you go boom.Lack off or incorrect.
well said
Nismo_Freak
Car: 89 Nissan 240SX
KaTdaToplesS13 wrote:A/r for compressor is .60 and for exhaust is .58. Also a friend of mine has ka-et and hes running stock injectors and hes doin jus fine so i think the 370's will be fine
A/R without knowing if you are running a T3 or T4 hotside is worthless.
If you are running a full T4, meaning T04E cold side / T4 hotside with those A/Rs you will have a good amount of lag.
If you are running a T3/T4 setup then you will have relatively normal lag.
This is assuming you are running moderated trims.
C-Kwik
You'll also want to know the trim. Actually, probably even moreso than the A/R. The trim on the turbine side will especially have a great effect on boost response and threshold. A 0.69 A/R on the turbine side is not necessarily laggy. On a smaller T4 Trim, you are looking at full boost of 7-8 psi at about 3500 to 4000 RPM. That is not very laggy. With a turbine trim on the large side for a T4, then you'll probably lag heavily regardless of A/R. You guys really need to start paying attention to and considering the trim of a compressor and turbine wheel when discussing turbos.
WDRacing
It'll work, I have a TO4E I was running on my RB20 for awhile. It had a .81 AR exhaust side and a 60-1 compressor. It wouldn't spool till 4900-5000. But that was a motor with 7.5/1 static compression and a manifold that was drilled for a T4 but the flange itself was a T3, so I didn't get optimum flow.
But definitly find out what the trims are.
Hey Alan, did you see where he asked about the T4? I didn't see a mention of T3/T4 anywhere but your post.
WD
uncle_louie83
.58 exhaust....ahh you will be fine...yes the trim levels are important but that turbo wont be that laggy...your a/r is smaller than mine so dont worry man
lewis
uncle_louie83
btw....your 370cc injectors are good for 250hp...think about upgrading....maybe a mustang 4.6 gt fuel rail...and some 450cc dsm injectors w/ inline resistors...and SAFC and you will be fine to 300hp...
lewis
uncle_louie83
lewis
p.s. and stock compression is fine...DONT ever do high compression and boost....ive been turbocharging cars for 5 years now and researched for 7....i know what im talking about when it comes to boosting an engine...
H.D.HUMPERDINK
Car: '92 240sx
Mustang 4.6 fuel rail? Is that a joke or does it fit?
WDRacing
With new mounts the 4.6 rail will work. The #4 injector is slightly cocked. But I ran 45 psi static pressure with 15 lbs of boost added on a 1/1 FPR with no leaks. I used 2 adel clamps and some spacers with long bolts to mount the rail.
WD
KaTdaToplesS13
The turbo has a T4 flange but how do I tell about the compressor. Also is the 4.6 mustang a v6 or v8 probly a v8. And wat years do they come in?
