T04E Compressor Map
Wakkolio
What do you guys think? I am not very good at reading this thing.
d240t2
What about it?
S14Zilvia
Car: '90 300ZXTT, '92 S13 coupe, '06 Ram 3500 Mega, '93 del Sol Si
You need to read Maximum Boost by Corky Bell.
Without knowledge of your motor the maps are useless.
If you're going with ka something like the t04e 50 trim from turbonetics is not bad. Depends on how much you plan on boosting though.
Get the book.
sil80drifter
Car: 1990 240SX Hatch
Corky ownz us.
Seriously, listen to S14Zilvia. Get it, or regret not getting it later.
sil80
king_johnthegreat
Car: Anything rolling fast
That's the comp. that I'm using in a T3/T04E super series ceramic ball bearing turbo. Mine is projected to make 350-400hp between 15-21 psi of boost (In peak efficiency). A lot of that has to do with the turbine trim and A/R, but it is a very nice setup for excellent mid to high rpm power. Because of the inducer's major diameter, it spools up pretty quickly for a turbo on the slightly large size. To make the best use of it, I've gone with a liquid to air intercooler. After all, it is my daily driver:freak John
UnderPressure
or pickup the latest issue of Turbo magazine its the all tech issue. teaches you how to read comp maps
WDRacing
Read that mag, Corky's is the best. Literally tons of great knowledge to be had there.
Matthew
Here some info:http://www.honda-tech.com/zerothread?id=142398
What type of VE numbers do you guys use for a ka24de?
