sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Mon Feb 03, 2003 6:25 pm
I am posting a picture to explain my logic in comparing the T62-1 with the T04B of trim 62 (both in and out) and A/R 0.84.
After calculating my Maximum Total Airflow, which turned out to be 392 CFM, or 30lbs/min, and my highest PR which at 10psi is 1.68, I've graphed an efficiency envelope on the turbonetics provided efficiency map of the T62-1.
As you can see in the pic, the red square represents the efficiency envelope, the blue dot being at the highest efficiency level (max rpm, max boost, highest PR) and the green dot representing the lowest boost/low rpm situation. It looks to me like the blue dot is between the 75% and 76% marks. This is pretty damn good, if you ask me. With other T04B charts, I barely came within the 74% circle, and never stayed in it. Here, if you assume linear increase of boost with rpm and PR (pinkish diagonal line), I'm in the 73% efficiency almost half way through the envelope, getting better as I boost more/increase rpm. Bear in mind that this turbo most likely outflows the T04B with the abovementioned trim and A/R. So that if I actually got that T04B, I could probably expect even better results.Someone tell me if my logic here is off or something. Also, to get the Max/Min Airflow and PR values, I've gone through some formulas of calculating those values, with an experienced member of another board showing me how to get them for my particular engine (SOHC).
sil80
