T04B 60A/R 63 trim will it fit?
AutoShadow
Car: 1993 Nissan 240sx
Will a T04B 60A/R 63 trim Turbo fit a KA24DE? If so, what manifold should I use?
Thanks...
skott.b
Car: 91 S13 ka-t
autoshadow wrote:Will a T04B 60A/R 63 trim Turbo fit a KA24DE? If so, what manifold should I use?
Thanks...
sure it will fit manifold is the Question at hand. my t3to4e is fitting nicely w/ space on a jgs log. buddy of mine sean kidd has something around that size on his S14 and is looking for something bigger now. ~skott
480sx
Car: 1996 Pearl White 240sx
Pretty much any turbo will fit on any car... I mean you can rig just about anything up. Thats going to be a turbo geared towards making 350-400 hp and up however. If your not going for 15 or so psi of boost or more, that turbo is below its efficiency range.
That turbo is a strait T4 right? Your going to need a t4 flanged manifold obviously.
I would say just go with a t3 flange, it will accomplish anything you want to do with a ka-t. Many more options for a manifold when your going t3.
AutoShadow
Alright thanks, anyone know of a good turbo for an automatic?
Any good sites to get a used turbo?
Thanks again.
480sx
If your gona stay with the stock ka auto, you want to get a small turbo. A t3 super 60 would be a great size and allow you to upgrade later with ease. Or if you want to spend a little more money, a t3/t4 50 trim .48 ar would give you fast spool, and the ability to make about 400 hp if you wanted to turn up the boost with a different transmission.
Get an external transmission cooler too, you will need it.
AutoShadow
Alright thanks again. Where would you go about getting a transmission cooler?
AutoShadow
480sx
Yea thats all you need, or something like it.
AutoShadow
Nice will do, can I just use a SR Turbo kit, and use a KA turbo manifold?
