Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Mon Feb 01, 2010 8:01 pm
I don't recall recommending anything other than New or Used OEM fuel pumps. But from what I have seen the fuel pumps internals start to rust because of the water in the gas. So if you can eliminate water in the fuel (use non E-10 fuel and remove and clean the fuel tank every time you change the fuel pump) you should be OK.
