Edit: No, the door closes and interrupts the circuit. I mean "normally open" as being the door is usually closed. Sorry.Red coupe wrote:If it is a normally open switch would a short really mess it up?Wouldn't a short circuit basically bypass the switch, closing the circuit and effectively doing the same thing the switch would do when the door closes in the first place?
The switches are brand new OEM out of the box. Tested on another vehicle.Red coupe wrote:How are you testing the switches with out a multimeter?
You sure? I don't do a lot of electrical diagrams, and the ones I do do use more basic line symbols but....The one on the left sure looks like it would be normally open compared to the the one of the right which looks like it would be normally closed... It seems like it would make more sense to use a normally closed switch so that when the door opens and releases the switch it would close the circuit for the light, but it really just sending a signal for the computer to interpret anyways.Dattebayo wrote:
Which in this case would make it appear as if the doors were open.
According to the FSM, the only lights that come on when the hatch is open is the dome light and the hatch light. Thanks tho!LAKE ERIE Z32 wrote:i know my light comes on when i pop my hatch in my z32 did you also try that one?
The foot lamps are removed, but they would be active all the time, the same with the dome light, but I have that set on always off right now...EazyBreazy wrote:Its possible datte. What's in the time control unit, is it possible that its gotten wet?. Do the foot/step lamps stay on too, or just the dome lamp? it may be possible that the illumination control relay is boogered up. Just throwing out random options that could be the problem lol
