it will allow caster adjustment if you have a caster split. I like that aspect very much.
also, if you get the SPL adjsutable ones, they feature a heim joint that has some movement built in so it wont crack your control arms
you may just want to get the heim joint/pillow ball/spherical bushings from SPL and pop them into your stock rods, if you dont need the caster adjustment.-chet
