t-78 question
mjjstang
If I had a 93 240sx with sr20det s14 and upgraded the turbo to a t-78 what is the best boost level to have it and how much power will I have. What would my 1/4 times be. One more thing is Would I have to upgrade the internals to get the best boost and efficeincy out of the t-78. Thanks for any info. Im just trying to figure out the best way to get into the 11s with the least amount of money. What else would I have to do to the engine/suspension/drivetrain. Thanks for any input.
I H8 UR DSM
standalone ecu720 or larger injectorsex. manifoldcustom downpipecustom lines 4" exhaust4 core intercoolerspecial fuel pumpcustom fuel railintake manifoldcustom pistons/rodsheadgasketboost controllergauges8pt roll cagecoiloversscatter sheildbrake upgradeslickslightweight rims
GodzillaFan
mjjstang wrote:If I had a 93 240sx with sr20det s14 and upgraded the turbo to a t-78 what is the best boost level to have it and how much power will I have. What would my 1/4 times be. One more thing is Would I have to upgrade the internals to get the best boost and efficeincy out of the t-78. Thanks for any info. Im just trying to figure out the best way to get into the 11s with the least amount of money. What else would I have to do to the engine/suspension/drivetrain. Thanks for any input.
do you have a 93 240 with an s14 sr20det? :confused:
if you just want 11's get a big t28/jwt ecu... and some tiresor a gt2835R+standalone if you have the $you could probably run a 10.9 with slicks/stripped car with the latter and still have a big powerband.
..you dont need a t78
Dori Dori
Car: Cars of course
I have serious doubts that a gt2835r would get a 240 into the tens. They'll make around 350whp at around 1.5bar.
I H8 UR DSM
GodzillaFan wrote:do you have a 93 240 with an s14 sr20det? :confused:
:bonghit Pass that good **** over here! you'll need plenty more than a big28/JWT ecu....if your gonna mention Aubrey, he had a bit more done to his car than that.
Jessehttp://www.rollhard.com
