T-3 turbo? What are the pros and cons? Installed on a Ka24DE?
MTC
Car: 1990 Nissan 240sx "Pig Nose"
Just want some input. I had initially looked at a T-28 Garrett turbo but found this Garrett T-3 cheap.
Chris28
Car: 92 s13 KA-T
It's just a different flange, and usually t3 turbos are bigger than t2 turbos. The t28 is a mighty fine turbo though. If you already have a t2 flanged manifold, stick with the t25. If you haven't started piecing anything together go ahead and get the t3. What are the specs?
480sx
Car: 1996 Pearl White 240sx
T3 is the ideal size for a ka24de. However going t3 means you pretty much have to spend more money. Custom downpipes are usually required, external wastegates are mostly used, ect.
T2 is the budget Ka-T rout.
MTC
Chris28 wrote:It's just a different flange, and usually t3 turbos are bigger than t2 turbos. The t28 is a mighty fine turbo though. If you already have a t2 flanged manifold, stick with the t25. If you haven't started piecing anything together go ahead and get the t3. What are the specs?
Your car in that photo is sweet I like the look of it!!! Thanks for the info.
hannibal
Car: Red Line to Glenmont
Compare compressor maps btw a T3 60 trim and a S14 SR T28. They are nearly identical. Unless youve found a good deal on the T3, I'd go with a used T28 or a new T3/T04E...
