2.5 VOLTS = 2.5 VOLTS = THE SAME AIRFLOWklattr1 wrote:for all those that are reading this thread and believe that by putting in a JWT ecu, Enthalpy ecu or whoever decides to tune ecu in the next few years, that you can put whatever turbo on your car and the air fuel ratios will be the exact same as before, please dont believe it cuz you will yield different results.
the constant variable: boost
lets say you have a mafs system with T25 at 2.5v of airflow. then you have mafs system with a T70 at 2.5v of airflow.
what is gonna be different about these two? rpm at which its provided
fueling is applied according to mafs voltage (load) vs rpm so the fuel % value would be different for the given 2.5v of airflow.
and yes, JWT does dyno tune cars. they dont put Clark in his little room and expect him to guess or simulate what everyone is running. the dyno tune with certain turbos and expect the client/customer to use that or something very alike which wouldnt throw the air fuel ratios off base. so with that in mind, JWT didnt as well dyno tune their 50lb/cobra mafs program with a t3 turbo.
You use the same amount of fuel for the same amount of airflow! The ECU cannot enrichen the mixture! So, as long as the GT1000 Pratt-Witney turbo you run on the car pulls the same amount of air as the GT12 you were running before the resulting amount of fuel injected is the SAME.
You are thinking on the basis of a MAP system where the system measures absolute pressure and not FLOW.
Stop saying "I have no credit in this arguement" and actually sit down and THINK about what I am saying.
