t-3 4 da CA
Und3rprshUr
Car: My 300Z
whats needed to bolt a t-3 to the CA manifold ?
slw240sx
Car: 1990 Ca18det 240sx Hatch
one of our custom manifolds!!
Und3rprshUr
Car: My 300Z
Nathan
you can weld on a T3 flange, I think boostboy posted a picture on here somewhere of a customer who did it...flanges are only like 20 bucks so I'd just do that if your looking for the cheap way :)
drumma022
i have done it, and i can send you a pic via email as soon as i get home... IM me at godzilla240sx tonite around 2:00am if you are awake then
GoofyATX240
I gotta see that.
NeedCAforS13
Car: CA swapped S13 coupe
drumma022 wrote:i have done it, and i can send you a pic via email as soon as i get home... IM me at godzilla240sx tonite around 2:00am if you are awake then
you gonna be up at enjuku today? he was asking about the t3 for my ca...and we weren't sure how well welding to a cast manifold would work...anyways, i'll stop by later, or IM you or something...
Sean
NeedCAforS13
come on someone's gotta know some more about this...
can i put a z31 t3 on my stock cast manifold using a welded flange???
Sean
Nismo1182
Car: Z06
you can weld a new flange on there. See if you can borrow a Z31 turbo and just hold it up to the manifold to see if it clears everything.
slw240sx
im guessin around 250-300$ for one of our manifolds ... log style or tubular your choice i think log syle will be a cheaper alternative
Und3rprshUr
Car: My 300Z
Someone needs to make a manifold for the VG30ET. i promise the sales would go through the roof if price was good enough.. maybe you can ?
slw240sx
well ill see what i can do ill have to run by the yard and grab a manifold
Und3rprshUr
Car: My 300Z
make sure its a turbo manifold.. and man i PROMISE if you made on tons of them would be sold. how much you think you would charge?
undertaker
Car: C33
i ran a (fwd) CA with a T3 flange welded onto the standard manifold for years and never had any problems with it. make sure the welder is experienced because cast is a little harder to weld.
