Q45tech wrote:Just reminising about tires of yore.
Each tire construction is somehat different so you can't go by car tire placard pressure when you change tire models on car.
The 51 psi tires were created to improve rolling resistance [help with mpg] not to increase performance........with 51 psi tires the sidewalls are thinner more elastic [ballon like] and weaker from side impacts.........vs old fashioned 35 psi max tires which had some real beef [strength in sidewall] but couldn't expand.
Not sure I understand your question?
maxnix wrote:Just noticed some SZ50 EP are again available at tire rack including the 245/50-16 size. No 225/60-15, though.
qship96 wrote:Based on q45techs above info and his comments on tire brands,question--why would any q45 owner NOT use the michelin pilots,especially in stock 15 inch,we are lucky they still make the 225& 235 60 15 in such a strong tire-------I say if we all buy these,maybe they will not abandon the tire in this size and we will have a good safe tire to keep our q on stock rims!
Sigh ... it was a tough decision. The four tires were coming from two different Tirerack locations, probably had two different manufacturing dates and lots, etc. I would not have been able to spin them up before receiving them, and Grant could not assure me that he would be able to change one if it proved defective or (here is the clincher) if I wanted to replace one due to a driving mishap later on.Quote »They are the best combination of noise, wet and dry performance, ride and handling I have driven. The Michelins may be better built or have a stronger carcass, but for the first few thousand miles, they don't measure up to the SZ50 EP. In the wet, the Michelin XGTV are just not even in the same state, let alone the same ballpark, as the Firestones. [/quote]maxnix wrote:All in all, if I had a chance to buy the last 4 SZ50 EP, and they spun up within specification at Tirerack, I would do it.
I would still read the actual sidewall of a P245/45R17 SZ50 EP. Even if it says 89Y on the chart, the 245/50-16 says 97 on the sidewall. Can't imagine it would fall off that much between the two sizes. Maybe Firestone didn't want to sell too many of them.ddrumman wrote:Hey Q45 tech and the rest of the gang,
I’m still puzzled about what tire to get for my new 17x8 rims.
