SZ 2.5 inlet piping question
sns00
Car: 1994 Z32 TT
2006 Kawi ZN1
1994 Ram 2500 5.9L TD
Hello Forum; :confused: engine pull required to install a SZ 2.5" turbo inlet piping kit?; :confused: is it necessary to remove the manifold heat shields for the new turbo inlets adapters? or :confused: aftermarket manifolds are a must for clearance?
Regards.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Manifolds are not the issue. Motors mounts are. BDE low profile mounts or grind down the OEM webbing of the aluminum mount.
sns00
Car: 1994 Z32 TT
2006 Kawi ZN1
Thanks a bunch.
