audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Fri Jan 07, 2005 8:56 pm
I would suggest you start troubleshooting with the headunit first, using the direct-attached 4x6's (disconnect the power or remote-on for your amps to do this). After disconnecting the amps, so they don't power on, troubleshoot the whine from the headunit and get that fixed. Next, connect a single amp up and check it for static/clipping/etc. Once that is resolved, hook the other amp up and do the same.
Take it one step at a time starting at the beginning or you will have a horrible time finding the problem(s). You may want to clean your battery terminals and check your battery grounds as well.
