synthetic vs synthetic blend
waxfreak
Car: 07 G35 Sedan
My service shop only uses syn blend and conventional oil. I've waited till my second oil change to use a full synthetic. All of my prev cars had synthetic. Do any of you bring your own oil for them to use? If so, do they charge you the full price?
ArizonaG35
Car: 2007 Infiniti G35 Journey Sedan/Premium Pkg. Platinum Graphite
I bring my own oil and the dealer discounts the price of the oil change to reflect "less 5 quarts" so I end up paying more for the full synthetic but the guys at the dealer are real cool about me bringing my own oil...
szh
Car: 2018 Tesla Model 3.
I buy my own oil (6 quarts of Mobil 1 Synthetic 0W-40, but I plan to try 5W-30 this time around) from Kragen or Pep Boys. The Infiniti dealer discounts me some dollar amount for them not using 6 qts of their dino 5W-30 oil. It is 6 quarts in my case, because my V-8 takes that amount of oil for a change (also including the filter being changed), the V-6 is less, of course.
On alternate times, when I am just changing engine oil and not having anything else done on the car, I take my own oil, my OEM filter and crush washer (which I buy in 6 packs from http://www.everythinginfiniti.com) and take it to local shops. Then I pay about $10 to $12 for the work to be done.
If I could raise my car and get under it safely (I do not like jack stands ... a mild earthquake in the area, and I might die if the car fell off the stands ), I would change the oil myself ... it is easy enough to do!
Z
Gimli G35
Car: 1996 Lexus ES300
get some ramps , and just use e brake and shimmy the back wheels
i HATE jacks also , an OEM jack from my parents maxima had failed causing it to drop the car and nearly took off my foot..
I dont take my own oil , the shop i go to is owned by my brothers friends and they keep a pretty good assortment of oils for different asian cars
joe603
Car: 2014 Durango R/T
NEVER, NEVER go under a car with the OEM jack!!!!!!!
szh
joe603 wrote:NEVER, NEVER go under a car with the OEM jack!!!!!!!
Oh, most definitely agreed! . I have a hydraulic jack that is way better. But, even then, it is only used to raise the cars to rotate tires. In theory, I could use jack stands to support the car to get under it, but I don't like those either. My imagination runs wild as to what could happen if the jack failed or a mild earthquake rocked the car off. A lift is way safer, since you have, in theory, a few more seconds to get out of the way of a car falling off a lift.
I'd like to do my own oil change to make sure that everything is done right, and also to teach my son, etc., so a ramp is probably the way I would do it for sure (like Gimli G35 mentioned). But, given that the local shops charge me $10 to $12 (depending on the place I go) for the work, and they deal with the used oil and filter too, it has been far simpler to be lazy!
Z
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
no help here, I have always changed my own oil.... rhino ramps!
Gimli G35
sad thing about that , i wasnt going under the car lol , i have a ramp for going under at home .
suby01
Car: 2007 Infiniti G35x
i just had my first oil change this weekend and im gona have the dealer do them since i have 4 free oil changes. BUT after that i think i will do them myself. save time and $$. but what type oil should i tell the dealer to use so i can use the same one thereafter synth full synth or w.e else there is. tenks
telcoman
I use a 3 ton hydraulic jack and ramps. I jack up each side & place the ramp under the front wheel. Then i move the jack to the other side & place the ramp under the other front wheel. This works out real well. I change my own oil every 3k- 3.5k miles using mostly Pennzoil 5w-30 2006 G35 6 Speed manual 36k miles
Telcoman
