Vinny14369 wrote:I just bought a G37 6 MT that now has 200 miles on it. Now, the question: Synthetic or Regular oil for G37?
OK. Before posting this question, I’ve researched throughout the NICO forum for prior posts so as not to be duplicative, as I’m sure I wasn’t the first Infiniti owner with this question.
What I’ve found is justification for both, but mostly with people leaning to the use of synthetics. The debate I’ve seen is WHEN to start using synthetic oil. I am seeing people start doing this at around 1,000 miles and then continue to do so for the life of the car. I’ve also seen owners begin using synthetics at 3,750, 5,000 and 7,500 miles.
As all of you, I want to take the best care of my new investment. In light of the above, I plan on using synthetic oil, but am not sure WHEN my first oil change should be and WHEN I should use synthetic and WHICH brand. I’ve seen a lot of talk about Royal Purple, Mobil1, etc....
All of the prior posts I’ve seen were with regard to oil changes on G35s. I’m assuming that the advice is the same with a G37, but I wanted to be sure and check.
All suggestions are appreciated. Thanks very much!!
~Vinny
Vinny
Congrats on the new vehicle
As others have written I did my first oil change at 1000 miles and every 3 to 3.5 thousand since except the last one which I did after 3900 miles after a trip to Florida. I use factory oil filters and buy my oil on sale.
I've done 24 oil changes on my G over the past three years. If you have ever seen oil come out of your crankcase after 3 to 4 thousand miles I don't think you would ever decide to wait until 25 thousand miles?That is a good way to ruin a 40k automobile in my opinion.
Every time an engine cools down an amount of condensation (water) collects in the oil. Over time this turns into sludge which looks and feels like dark thick mud. Any mechanic that works on engines can tell how often oil was changed on a vehicle just by dropping the oil pan. Doing it yourself can save you a considerable sum over the life of the vehicle.
Since frequent oil changes will prolong the life of your engine by reducing sludge buildup it is my opinion that using expensive oils are a waste of money.
As long as the oil meets API standards as recomended by the manufacturerthere is no need to waste money on expensive oils.
Just my $.02
Telcoman
