Pescakl1 »
https://forums.nicoclub.com/pescakl1-u98038.html
Tue Mar 09, 2010 9:23 am
That is not true at all: As long as you change your oil regularly, changing from synthetic to dino back and forth won't do anything to the car.
It seems the myth came from some cars'owners that did not change their oils for a while using dino oils, then use syn oils for some time.Since the old dino oils stayed too long in the car (oil not changed at proper intervals), it clogs some parts of the engine which dried some gaskets and other parts. Syn oils having more cleaning properties (more aggressive chemical components), it cleaned the engine exposing the dried gaskets. Since these dried parts are used to avoid leaks, they could not do their jobs and engines started to use some oil. Going back to dino oil did not resolve the issue.
But instead to blame the bad maintenance of the engine (the owners), it was easier to say that was caused by the oil. Syn oil was the new thing at that time, so it took the blame (as for now, thin oils are blamed for oil consumption, even if the problem still resides in the hand of the owner).
Maintain your car with any oil you can find on sale and it will work fine for a long time. The important part in changing oil is not the type of oil you use, but the fact that you change the oil.
