ThisIsSparTTa wrote:What do you mean recently re-sealed? If the engine was rebuilt, its not recommended to go back to synthetic for 3000 miles, but that's for the piston rings, not other gaskets and seals. Otherwise synthetic is fine. Minimum of 10W-30 unless you're in a super cold environment (not SoCal), then you can go 5W-30. I was running Royal Purple before my rebuild.
