Deferred maintenance my a@*!! I can pull all of my maintenance records! How many times have you changed your valve cover gaskets and it wasn't leaking!? My car wasn't leaking before! Not once did I bash M1! If you read correctly, I said that It was a superior oil! If it has seal conditioners, then it wouldn't be leaking right!? I'll rather listen to the Infiniti technicians than listen to you maxnix since you were one of the people who said it would be no problem to switch. If they told me that the leak was caused because of the switch to synthetic, then I believe them. Remember, we should trust the diagnostic decision of true, qualified, Infiniti technicians right Thought so.maxnix wrote:Nothing to do with M1 (which has seal conditioners), but a lot to do with deferred maintenance.
Thems fightin' words!It was most likely a coincidence. But in my opinion you should not have changed. Change your oil regularlyand you are fine.NightRiderQ45 wrote:
By the way maxnix, you're the one who said that OEM brake pads were ceramic, WHICH THEY ARE NOT!! Obviously, you don't know as much as you think you do They are made of more of an organic material, not ceramic! I didn't want to call you out on your previous post, but since you tried to bash my maintenance on my car, I just thought that I would let you know that you should do some research before you post answers or just call Joe for "true" information!
You've got a pretty good AB experimental design, wish there was a way to do an ABAB design.NightRiderQ45 wrote:Good Morning everyone. I just want to vent out my frustrations about my "mechanical free" car until now. Many of you might remember two months ago I started a thread asking if it would be ok if I switch from mobil clean 5000 to mobil 1, even though my car has high mileage (169k). Well, I was still reluctant to change over because I was afraid my seals would leak using synthetic; but after speaking with the "Q45 gurus" on this forum, I switched over. Bad mistake Since, I've driven my car from Oklahoma to Alabama twice since the switch and I noticed a burnt smell once I exit of the interstate. I told myself that this "better be not what I think it is"!! Knowing that my car never produced that smell before, I took my car to the Infiniti dealership yesterday to speak with some Infiniti technicians
The technician remembers my car coming in there previously to fix the ECU (remember BestBuy screwed it up) and he asked me why was my manifold full of oil and it wasn't leaking before?! At first I thought he was joking with me, but then it clicked! Damn it, I switched to synthetic oil! I explained to him that I switched over to Mobil 1 and he said that was a bad decision considering my mileage. He said with the mileage on my car, the seals and gaskets are hard, and since Mobil 1 is such a superior oil, it was able to penetrate the gaskets, thus spreading all over my manifold! He said I'm lucky it wasn't in the rear man. Long story short, my valve cover gaskets are leaking badly now and $456 to fix!! He told me once he fix it, to go back to dino Mobil clean 5000 and my car will be ok with my strict schedule of changing my oil. So for future people, if you have high mileage on your car, PLEASE DON'T SWITCH OVER TO SYNTHETIC! It WILL cause oil leaks. I'm a living testament!!
Yeah, I know. After reading some of the posts, I'm quite sure that the gaskets wouldn't last forever. Q451990, I might have a record with OEM gaskets lol. I glad to see that other people have had the same experience that I have and I'm not crazy. Like I stated before, I'll fix the problem and drive it for another 169Kbullittandy wrote:
If its any consolation, your gaskets were going to leak soon, mine started at 200K-and now that I think about it that was about 6000K miles after I switched to synthetic after he PO used regular. How bout that?
I did a write up on replacing the gaskets and its straightforward other than one bracket o n the driver's side, the post was recently near the top-check it out.AlabamaDan wrote:If you fix the gaskets yourself it will be about $75.
Spoken like a true conservative, as an Iowa farm boy or anywhere farm boy.ScottJackson wrote:I also think the gaskets were gone before the oil change. The synth probably cleaned out the gum/varnish and that was it. Once it's freshly sealed up again, keep running the Mobil1 if you want. Personally, I run regular old dino oil as I don't see the advantage in using synthetic except for cars that get driven very hard (oil gets hot and synthetic is much better for high temps). For example, all of the vehicles at my farm are over 200K miles and none smoke on start up or use oil between changes, yet they've all had nothing other than regular valvoline or wal-mart oil. Some of them like my red '92 Ford with 253K miles get oil changes every 5000-7000 miles, on regular cheap oil. As of 230K miles, it still had 38psi oil pressure at hot idle and doesn't use a bit of oil between changes. I could probably treat it better, but the body is gonna fall apart before the engine goes. My 540i gets synthetic, but just because it had it before I bought it and it does get run pretty hard. It also sometimes sits a long time between starts.
Thanks Bullitt and AlabamaDan!! I didn't think that it was very straight forward. I can get the gaskets at the Infiniti dealer for $25 a piece. Infiniti was charging me $420 (4.2hr) just for labor and another trusty shop is charging me $286 (3.7hr) for labor. It it's something that I can truly do, then I'll try it. If it isn't, I'll pay. Bullitt, what title of the topic?bullittandy wrote:
Thanks will do. No, I have the iridium ngk plugs in there. Also, I figured that I will pay someone else to do the work. After I looked at Andy's post I figured I'll pay someone else to do it. I don't have the time or great weather to accomplish that task. It's 10 degrees here in Tulsa. BTW, good post Andy.AlabamaDan wrote:I think Jeff Williams did a write up too. While your in there change your spark plugs. Are the OE?
I think I made the comment that the job was only worth $300 to me. so any labor price below $300 I would rec that you have someone do it-and you've found it.NightRiderQ45 wrote:
