Synthetic Oil in I30?
johnc
I have an 1998 I30 with 80k. The car runs perfect and I currently use 10w-30 in it every 3500 miles. I have been thinking about going over to Synthetic oil, but some people have told me that with an engine with that many miles on it that it could do more harm than good by removing the 'sludge' that is in the engine that might be causing the engine to run fine. What is your take on this, and if I did go to Synthetic, how often should I change it and the oil filter also.
DAEDALUS
Car: 1990 Infiniti Q45
The concern is not with dislodging something that's holding the engine together; the concern is with dislodging something that will end up somewhere else where it can do some harm. It sounds like you have very good maintenance habits. Given that and "only" 80k, I wouldn't worry about there being much sludge in the engine. I see no problem with going to synth; only benefits. If sludge is a concern then try a gradual cleaning process over 2-3 months using oil changes every 2 weeks, and gentle cleaning just prior to each change with a little BG cleaner or (I think) transmission fluid, which is reputed to have cleaning/solvent properties.
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
A good compromise is a synthetic blend. I used Valvoline Durablend for about a year in my '92 Q before switching to full synthetic.
I get much smoother response in high rpm range with full synthetic. Also distributes better on cold starts.
Go to T-3 and buy some BG 111 (used to be called BG MOA) oil additive. Use half a can or a full can per oil change. Will make you engine run "like buttah". (More anti-wear additives).
PalmerWMD
Car: 2004 350Z
Every car I ever bought I switched to syn right away, regardless of milage."some people" are often wrong..;)
Fred...:)
