s13sr20chris »
https://forums.nicoclub.com/s13sr20chris-u7880.html
Sat Sep 11, 2004 2:30 pm
i am not sure about the synthetic fluid being stock(doubt it). i will say that redline is good as is motul, mobil one, etc. IMPORTANT: m/t takes a gl-4 gear oil whereas diff takes a gl-5most gear oils you buy at the store are going to be gl-5(even the cheap stuff). gl-5 has special antiwear additives that corrode synchros. SOLUTION: us redline mt90 in your m/t and some other stuff(like easily obtainable mobil one) in the diff.
