I'm going to flush my brake fluid and was wondering what you think of Valvoline SYNPower brake fluid. I've shopped everywhere where I live and could only find no name stuff and prestone. I ended up ordering some Valvoline SYNPower Full Synthetic, because the Valvoline distributor hooked me up with free overnight shipping from their warehouse.
Here is some info:
SynPower High Performance Synthetic Brake Fluid is recommended for ABS, hydraulic drum and disc braking systems and hydraulic clutches requiring DOT 3 and DOT 4 fluids. Its premium, synthetic, low-moisture formulation provides superior anti-vapor lock protection. It has a high dry-boiling point up to 500°F that reduces the risk of fluid vaporization and possible brake failure.
*Exceeds DOT 3 and DOT 4 specifications *For most ABS, disc or drum brake systems *High boiling point reduces risk of brake failure *Compatible with conventional brake fluids
http://www.valvoline.com/produ...d.pdf
Does anyone else use this stuff? Is it recommended?
If you scroll to the bottom of this page, you can see a comparison chart:
http://www.stoptech.com/tech_i...shtml
